Oil to Gas conversion.. Before and after pics
Check out this old guy. Approx. age is 60 years old. I never had a problem with it in the 4 years I have owned it besides its apatite for #2 oil. Converting to Independence 11. Pics to follow.
    Steamhead Member Posts: 18,186
    edited October 2011
    I wonder
    if that Mohawk burner is a re-branded Sunray? The housing design makes me wonder.... if possible, take a pic of the end of the air tube (part that sticks into the boiler) and post it.
    If it is a Sunray, please don't throw it out!
    Consulting
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    A header for christmas
    Looks like you will finally have a proper header on that system!
    The old boilers were so large that the steam chest was enormous, and protected the knucklehead from his own mistakes!
    Did you do a radiation survey to determine the appropriate size of the replacement?
    Don't forget that a vaporstat, and good low-pressure gauge+generous main venting will let you begin saving money right away instead of waiting until next year!
    A metered water feed will alert you to damaging excess make-water.--nbc
  • Haviara
    Haviara Posts: 30
    Sunray
    Hey SteamHead,
    I'll do it tonight. What is the significance if it is a Sunray? Historical value?
  • Haviara
    Haviara Posts: 30
    Sunray
    Hey SteamHead,
    They were great burners
    whose company was mismanaged out of existence. We still see a lot of them in the Baltimore area and I like to keep as many parts for them as I can. With proper setup they run quite efficiently.
    Consulting
  • ChrisJ
    ChrisJ Member Posts: 17,060
    edited October 2011
    Ah
    I was under the assumption that the older huge boilers with steam chests didn't need a header?
    My neighbors 60+ year old boiler is pipped in just like that, no header.  It also has an odd thing with two weights, maybe some sort of pressure relief?
    That was
    a regulating device, that controlled the draft dampers when it was coal-fired.
    Consulting
