Taco 4 zone circulator control
Tom Manton
Member Posts: 30
I'm having an issue with my 4 zone circulator controler. The system is an atmospheric wood boiler primary loop feeding a 40 plate heat exchanger with a single speed circulator. The secondary loop is running 2 Grundfos alphas through 5 grundfos zone valves, 4 radiant loops,and an indirect water heater.
I'm trying to trigger the primary circulator by switching zone 1 in the controler through the end switch position. On a call for heat everything switches as it should, the problem occurs when all zones are satisfied the secondary loop shuts down but the primary remains on. I have wired from the zone1 low volt supply to the end switch. If anyone can show me where I went wrong thanks in advance.
You need...
a sep. sr 501 just for the primary loop. then all the others w/ a sep. controller. ...(i think) Do you have a drawing?0 -
501
Thanks, that's what I was thinking too. My system is set up like that,0 -
Give Me A Call
Hey Tom, Tim D. Here give me a call and we can work through it. 401-369-0646 is my cell or 401-942-8000 ext 396 is my office line.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
