Utica boiler firing up but not then shutting off
rjd
rjd Member Posts: 3
I have replaced everything I can think of on my Utica boiler It gets flame but that its... Any help out there...
  • lchmb
    lchmb Member Posts: 2,997
    detail
    Could you previde a little more detail as to what is going wrong? System not circulating? System over heating?
  • rjd
    rjd Member Posts: 3
    He starts it up it clicks sometimes if fires but doesnt go beyond that. Changed gas valves, sending unit. Still will not fire up and stay on.
  • lchmb
    sounds like
    It is not sensing flame. It may be cheaper to have someone who has a meter to come in and check it. He could check the grounds and or flame rod.
  • rjd
    rjd Member Posts: 3
    Thank you for your help
