Utica boiler firing up but not then shutting off
rjd
Member Posts: 3
in Gas Heating
I have replaced everything I can think of on my Utica boiler It gets flame but that its... Any help out there...
detail
Could you previde a little more detail as to what is going wrong? System not circulating? System over heating?0 -
He starts it up it clicks sometimes if fires but doesnt go beyond that. Changed gas valves, sending unit. Still will not fire up and stay on.0 -
sounds like
It is not sensing flame. It may be cheaper to have someone who has a meter to come in and check it. He could check the grounds and or flame rod.0 -
Thank you for your help0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
