Utica boiler firing up but not then shutting off
rjd
Member Posts: 3
in Gas Heating
I have replaced everything I can think of on my Utica boiler It gets flame but that its... Any help out there...
detail
Could you previde a little more detail as to what is going wrong? System not circulating? System over heating?0 -
He starts it up it clicks sometimes if fires but doesnt go beyond that. Changed gas valves, sending unit. Still will not fire up and stay on.0 -
sounds like
It is not sensing flame. It may be cheaper to have someone who has a meter to come in and check it. He could check the grounds and or flame rod.0 -
Thank you for your help0
- 167 Indoor-Air Quality
