condensing furnace in attic
Paul_69
Member Posts: 251
in Gas Heating
can you install a condensing furnace in cold weather climate .
no recommended
Not sure which post to answer but I would not recommend it as service guy living in Colorado. I've been to many a no heat in the middle of the night during a deep freeze with the condensate trap frozen solid. You could use heat tape but thats another set of problems; fires, power outages making it useless, tape failure. My .020 -
dog house
how about building a insulated structure around furnace, well sealed with removable door for service.0 -
RE
Sounds sketchy. Can you insulate the attic, and condition it with the furnace?0 -
I wouldn't
Thats a lot of work, building a structure around it in an attic to pick up a little efficiency. Typically furnaces in attics are in large homes and only heat the upper floor with another unit in the basement doing the main level and basement. Upper floor furnaces don't run as often as the lower floor since most of the heat rises. So the payback with a higher cost of the 90%er and the extra work would take a long time. A 80% furnace with 2 stage gas train and a variable speed blower is a darn good option.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 992 Plumbing
- 389 Solar
