Need to drain Novan FX 1000D
I have a 29 year old Novan FXB 1000D heat exchanger. I now need to replace my roof and need to drain the Bray oil out of the system. I have a 2 page data sheet on the system which diagrams the system but does not describe how to drain the Bray oil.
I am discarding the system so need to get all of the fluid out o the solar panels.
Good luck with that...
Those modules had a special quick coupler on them that were made exclusively for Novan. Short of taking them off, it is nothing less than difficult to get the oil out of the system.
Brayco 888 is not real flammable under room temperatures, but it will dissolve any asphalt shingles it comes into contact with.
Are you in the Denver area per chance?
Getting rid of the Bray Oil can be done by turning it over to a recycler (Checker Auto Parts) You also might consider selling it on E Bay. I don't think you can buy it on the open market any more.
ME0 -
Thanks for the reply.
No, I'm located outside of Boston. The last time I had anybody work on the system was in 1999 when a bird (or other animal) chewed the wires and it stopped working. I am not sure who I would call to do drain the system this at this point but would rather do it myself if I can.
The stone lined storage tank leaked about 4 years ago and I stopped using the system.
I am willing to discard the heat exchanger since I don't use the system. How do I identify the couplers? Do I just cut them off with a hack saw and the fluid will drain out?
Any idea how much fluid might be in the system? I have two solar panels on my roof.
Thanks very much for your help.0 -
Silver connectors...
They are about 3/4" in diameter with a center plunger. They are actually a hydraulic quick disconnect like used on back hoes and other removable hydraulic powered equipment. Remember, this stuff is under pressure, and if it comes int contact with any other hydrocarbon products (carpet, paint etc) it WILL most probably dissolve the other material.
Under NO circumstances do you want to attempt to drain this system when in direct sunshine, unless you are in to third degree burns...
Once you have relieved the pressure, you can unscrew the connectors and replace them with boiler drains and properly drain the system and dispose of the Brayco 888. FWIW, Brayco 888 was originally developed as a hydraulic fluid for the Space Shuttle.
Proceed with caution.
ME0
