taco 503 zone panel
smitty_6
Member Posts: 6
the zone to my indirect hot water heater keeps turning on and off every couple of sec turning the circulator on and off . changed the cube relay seemed to solve problem for a little while any suggestions on what is causing this.
aquastat
Did you check your indirects aquastat? Wiring for lose connections?0 -
thanks
jumped out the aqustat found it to be bad replaced it everything working fine now0
- 50 Industry Classes
