vacuum steam
just replaced a steam boiler on a vacuum system. The boiler had a tee just above the water line, on the column with a trap piped to the vacuum return. What is that and whats its purpose?
  • TomM
    TomM Posts: 233
    pictures?
    Pictures?
  • Steam_Trap
    Steam_Trap Member Posts: 7
    edited October 2011
    was out snaping pictures
    Thanks for the reply here are some pics. the MM 150 is in the right hand corner of the pic. Above the LWCO is the Tee and strainer, then steam trap. after that theres a Tee with a check valve opened to open in.from there it goes to return line. any ideas?
  • Steam_Trap
    pics
    having trouble getting pictures on. Newbee! any ideas?
  • Rod
    Rod Posts: 2,067
    Use JPG Format
    Hi - This website will accept only pictures in .JPG format or files in PDF format.
    - Rod
  • Steam_Trap
    how about now
    Can u see this now?
  • JStar
    JStar Member Posts: 2,752
    RE
    Looks like an open swing check. But for what? Did this used to have a return going to it? Maybe someone thought this would act as a vacuum breaker?
  • Steam_Trap
    Doesn't look like it had anything connected to that check valve, and being that its after the trap it couldn't be a vacuum breaker for the boiler, only for the return line coming out of the steam trap.(I think). My question is what was the steam trap and return line doing there to begin with?
  • Steam_Trap
