vacuum steam
Steam_Trap
Member Posts: 7
just replaced a steam boiler on a vacuum system. The boiler had a tee just above the water line, on the column with a trap piped to the vacuum return. What is that and whats its purpose?
pictures?
Pictures?There was an error rendering this rich post.
was out snaping pictures
Thanks for the reply here are some pics. the MM 150 is in the right hand corner of the pic. Above the LWCO is the Tee and strainer, then steam trap. after that theres a Tee with a check valve opened to open in.from there it goes to return line. any ideas?0 -
pics
having trouble getting pictures on. Newbee! any ideas?0 -
Use JPG Format
Hi - This website will accept only pictures in .JPG format or files in PDF format.
- Rod0 -
RE
Looks like an open swing check. But for what? Did this used to have a return going to it? Maybe someone thought this would act as a vacuum breaker?0 -
Doesn't look like it had anything connected to that check valve, and being that its after the trap it couldn't be a vacuum breaker for the boiler, only for the return line coming out of the steam trap.(I think). My question is what was the steam trap and return line doing there to begin with?0 -
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
