Finally piping the header
Well, I've been putzing with my system and now that winter is just around the corner I'm finally getting around to repiping the near boiler sections. To any that have been following the <a href="http://www.heatinghelp.com/forum-thread/136523/guts-of-a-marsh-boiler-return-trap-with-pics">http://www.heatinghelp.com/forum-thread/136523/guts-of-a-marsh-boiler-return-trap-with-pics</a> Here's an inprogress photo of the soon to be new header. (the rusty fittings are just because our basement flooded 2 weeks ago, and some of the fittings that I had laid out ready to go did not get moved to the second floor, had a lot of other things to "save")
  • Ron Jr._3
    Ron Jr._3 Member Posts: 603
    Very nice !
    Try WD-40 on the rusty fittings . Keep up the great pipework !
  • crash2009
    crash2009 Member Posts: 1,484
    Lookin good Dee!
    Is that 2" coming out of the boiler, then dropping into a 3" header?
  • gerry gill
    gerry gill Member Posts: 3,078
    yes indeed..
    I'm likin' that..good job.
    gwgillplumbingandheating.com
  • ChrisJ
    ChrisJ Member Posts: 15,727
    Looking good!
    I'm jealous,
    I'm so far from being able to pipe my boiler in right now its scary. I probably won't be to that point for another 3 weeks.
    I have a question that will surely make me look dumb but thats ok.  What are the two pressuretrols for?
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • moneypitfeeder
    moneypitfeeder Member Posts: 249
    different animals
    One is a ptrol, and 1 is a vaporstat, not a dumb question at all...I just needed to have lower pressure control than the ptrol could give me. I have the ptrol wired to act as a high limit switch in case the vaporstat ever fails. The 2 gauges are the required 30 psi gauge and a low pressure gauge to monitor the vaporstat.
  • moneypitfeeder
    yep
    I wanted to get the driest steam I could, and allow for all the condensate to have room to drain without slowing down the steam. Just hard to come by 3" fittings around here but I finally found a place, they can thread for me too, which is great since I can only thread to 2" with my equipt.
