Energy savings
mjg
Member Posts: 1
Iam looking for an easy way to figure the energy savings for reducing the steam pressure from 115 PSI to 90 PSI on a 400 hp boiler
Not sure it can be calculated
you would have to track your fuel consumption before and after.
This sounds like an industrial type of system- tell us more about it.All Steamed Up, Inc.
Consulting0 -
What pressure is too much?
All the appliances which are served by the boiler must have ratings for minimum pressure requirements, and it would seem that any excess pressure from the most consumptive one will be a waste of energy.
It might be the case that one appliance which only needs a small amount of higher pressure steam could have it's own boiler with some energy savings.--nbc0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
