Automatic water feeder doesn't activate
GNO
Member Posts: 4
Hello All,
I have a Weil-Mcclain boiler EGH-95 and the automatic water feeder does not activate. The boiler has the float type drain off valves and I can manually activate the water feeder. Are there any suggestions to try before bringing in a proffessional?
Thanks!
Thanks!
RE
Is this a new problem? Has anything changed on the boiler?
Sounds like the LWCO isn't sending a signal to the feeder. Could be a loose wire or missing jumper.0 -
follow up
Yes a new problem, nothing new has changed on the boiler. Just starting it up for the first time after the summer season.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
