Automatic water feeder doesn't activate
GNO
Member Posts: 4
Hello All,
I have a Weil-Mcclain boiler EGH-95 and the automatic water feeder does not activate. The boiler has the float type drain off valves and I can manually activate the water feeder. Are there any suggestions to try before bringing in a proffessional?
Thanks!
Thanks!
RE
Is this a new problem? Has anything changed on the boiler?
Sounds like the LWCO isn't sending a signal to the feeder. Could be a loose wire or missing jumper.0 -
follow up
Yes a new problem, nothing new has changed on the boiler. Just starting it up for the first time after the summer season.0
- 117.5K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
