How would you
Techman
Member Posts: 2,143
best, cycle/stage/control a chiller system. 42-44* load temp, with ten 15t compressors ( five 30t 2 stage units) ,and the load varies a lot .Thanks!
Staging
There could be a number of options depending on how it was designed. Are they using half of the 15 ton and 2 or 3 30 ton to control load? Maybe they are Controlling using Lead /Lag scenario. There is some major power consumption happening and I'm sure they try to keep it to a minimum.
Just some thoughts
Mike T.0 -
Chiller stageing
Mike T. How r u ? I'm good too!!!
Right now they have 5 Ranco electronic temp controls w/ the probe style sensor all set within the 42-43-44* range. There's GOTTA be a better way! So I'm getting some info going so I can sound professional when I present my little story to the customer. Both load and source water piping is parallel piped , 1st unit in ,1st unit out. In 8-9 years there's been 8-9 fatalities of compressors. I'm the new kid on the block!!!! And I smell something very interesting here, very interesting indeed! But, I need a little bit better idea of a better way to do this, than my better way at the moment ! So ,being curious , what is a better way?0 -
Control
Doing well Terry, trying to stay busy. I guess this is one of those scenarios in that you have to be there to actually see what they have, load requirements, product or space to be maintained at a given temp. Sorry, I have no quick answer, but you are on the right track. I to provide a customer with research to back up my plan of action in the presentation.
Keep me posted as to your progress and final set up of your plan. Good luck and remember you and I know the right place to go with questions or opinions,....."The Wall" of course
Mike T.0 -
chiller control
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
