outdoor reset
lupi
lupi Member Posts: 3
Sould I add an outdoor reset to a thermoflo owb boiler? Some have said its a good idea. a friend said it will rot out the boiler.
<a href="http://www.williamson-thermoflo.com/en/thermoflo/products/boilers/oil-boiler/owb-oil-fired-water-boiler.aspx">http://www.williamson-thermoflo.com/en/thermoflo/products/boilers/oil-boiler/owb-oil-fired-water-boiler.aspx</a>
  • Jean-David Beyer
    It depends.
    If it is a non-condensing boiler, you have to adjust the reset so that the return water temperature to the boiler is not too low. I am not a professional, but I believe in that case, you do not want the return water temperature to be below 140F. You would not get the adventage of condensing, but the reset should still provide some benefit. You might wish to calculate the payback time to see if it is worth the trouble.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    edited September 2011
    10% Guaranteed
    http://www.beckettaquasmart.com/
    Been using them on every oil boiler install for almost two years with great results
  • lupi
    tekmar
    I was looking at the tekmar 256, Is the beckett better for my boiler?
  • Charlie Masone
    Charlie Masone Member Posts: 66
    AquaSmart
    The Beckett AquaSmart and ODR should have simlar results on typical Baseboard or convector systems, on larger systems with big piping and radiators ODR may have an advantage.  ODR should be an option on the AquaSmart within a couple of months.
