Any ideas
Andy Stack_3
Member Posts: 39
One of our employees took this off an old steam system when he woked for someone else. Just checking to see if anyone has seen this before.
Hmm.
Looks like a modulating supply valve for a radiator in a vapor system, Andy.Retired and loving it.0 -
Valve
Andy, what size is the thread? 1/8", 1/4" If its that small could it be an adjustable air vent for an Early Steam System?0 -
I has an 1/8" pipe thread
Thanks Guys0 -
Yikes!
Could be an early Paul-system type of vent. Here's a Pemberton vent. This one had a cork inside of it. It took the place of an air vent. The outlet connection ran to an ejector on a steam engine. The ejector sucked the air from the steam system. When steam hit the cork, the cork swelled and stopped the steam from traveling down the vent pipe.
Can you take pics from other angles, Andy?Retired and loving it.0 -
The lever
What does that do, Andy? Does it turn or lift?Retired and loving it.0 -
lift and turn
Dan
It does both lift and turn.0 -
steam engine
It looks like a steam engine oiler, or one to a hit and miss engine.0 -
Google images
Just looked at hundreds of Google images for that, Tim, and I think you're right. Thanks.Retired and loving it.0 -
Is it a McCoy?
And why would that have been on a steam heating system?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Might be
a sight-feed lubricating device. Did it come out of a larger building that might have had a steam-powered generator? Is there a name or trade-mark on it?All Steamed Up, Inc.
Consulting0 -
Andy, is there
any patent info on it we can research with?gwgillplumbingandheating.com
Numbers
Hi Jerry
No Numbers but after a little cleaning Penberthy Injector Co. Sentry NO O
Made in USA
One of our new employees said the took of a steam system, looking like a steam engine.
Thanks Andy0 -
i think your right.
i think this may be the patent for it.gwgillplumbingandheating.com
I think that spring-closed style flapper is a dead give-a-way for an oiler. And the top handle is a primer pump?0 -
Or...
...not a pump, just a seat lifter to let the oil in.
http://www.etsy.com/listing/69167689/antique-penberthy-injector-co-brass
http://www.smokstak.com/forum/showthread.php?t=870130 -
Here are two.
https://secure.wikimedia.org/wikipedia/en/wiki/File:Radevormwald_Dahlerau_-_W%C3%BClfingmuseum_-_Dampfmaschine_05_ies.jpg
These are on a stationary steam engine. Most steam locomotives in recent use used power oilers.
Right: lift and turn. When lifted, oil dribbles out (very slowly). When not lifted, it is shut off. The valve is a needle valve and turning adjusts the drip rate.0 -
"Thanks Guys
it was fun. Gerry our you going to Dans class next week?0 -
can't
this time..i think steve will be there tho.gwgillplumbingandheating.com
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
