USAV vents?
ChrisJ
Member Posts: 15,713
I just got done swapping out almost all of my vents with the Hoffman 1As. Have two left to do, one of which I need to drill out and install a bushing.
Anyway, most of the vents I pulled off say USAV on them. A few say USAV 1A which seem to be an adjustable, yet very very slow vent even wide open.
Who is USAV? Are these vents even worth my holding on to, or should they just go in the garbage can?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
USAV
My local hardware store started stocking those about 8 years back so I used them on a couple of my radiators. My experience with them was not good, they started to spit after a year or two. I'd hang onto one for an emergency replacement and dump the rest.
3PSI gauge0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
