Flatp plate heat exchangers
Tim_5
Member Posts: 37
Does anyone have comments on small flat plate heat exchangers for domestic hot water/radiant floor and solar heat transfer.
Pretty vague question, just want to get some basic comments
Thanks,
Tim
Thanks,
Tim
We Use Them Regularly
The only real issue that we normally experience is scaling when used on an open loop. In that case, we install isolation/purge valves like you would with a tankless water heater so it can be de-scaled.Bob Boan
Re: flat plates
I use them quite often for commercial dhw production. We use the GEA heat exchangers and oversize them for lower temp boiler water to keep in condensing mode. Try to size boiler temp to dhw temp as close as is feasible for this.0 -
great online simulation
flatplateselect.com
My flat plate heat exchanger works great for DHW0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
