Hot Air Thermostat
billyL
Member Posts: 3
My Brother-in-law bought an 20 year old hot air heated house. It has an AC evap. coil installed but no outside condenser. His thermostat has a fan only button but it doesn't work. Should it work without an condenser unit and might a new thermo help?
do you mean
Are you trying to get the ac running? If so you need to complete the installation of the system. Sounds like someone put the coil in the plenum with plans to add ac and just never finished the job. You do need the condensor. You can however put a t-stat on that will control the blower on the unit if that's all you want..0 -
Furnace Setup for A/C
Check to see if the furnace has a "G" terminal on the low voltage terminal strip where the thermostat cable connects. It should be connected to the "G" terminal on the thermostat.
If it's an older Lennox furnace, it may be labeled with an "F" terminal.Bob Boan
Hot air Thwermostat
Thanks Bob for you response I'll check for the green? wire at the thermostat and furnace next time I'm there.0
- 120 Geothermal
