help with leaky #67 MM compression tee
Joseph_4
Member Posts: 319
Hi.
Installed a new #67 It wasn't leaking and all was fine- then whole LWCO 67 got moved and started to leak from compression fitting into tee. removed redid a bunch of times. it still leaks. A tradesman told me in my local plumbing supply to turn the tee up and use regular 3/8 rough brass for a toilet or sink and create an upside down J. He said he has had this leak many times. is there anything wrong with this? heard to get a new L shaped 3/8 pipe on order is over 40 bucks!
Thanks
Joe
Thanks
Joe
Make it work.
Find pipe and fittings that are the same size (either 3/8 or 1/2"). That line is just an equalizer.0 -
I've used
3/8 flare fittings and oil line to make the connection . In an absolute pinch we've soldered the compression fitting .0 -
yes a standard tee with a male by compression
adapter, or as Ron said, a flare fitting (which is better) with standard tubing will work just fine..as Jstar said, it only has to equalize the pressure.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
