need HVAC supply house near manchester Vermont
Steve Whitbeck
Member Posts: 669
Hi I need the name and # please
Steve
Steve
vermont supply house
you have two Sid Harvey's in vermont....Rutland phone #802-775-8855 / williston phone 802-658-4072 ... / hope these help.. Steve0 -
Supplier
Bell / Simons Burlington 802-862-87050 -
Your best bet....
Is to go to FW Webb in Bennington. Its 30 Min. south. Rutland and Burlington are over an hour North.
240 East Road, Bennington - (802) 447-23120 -
supply houses
they are all good, Sid's usually least expensive /// just my $.02 worth // 40 plus years experience..// still do not know it all // but trying to keep learning..0 -
Supply house
Thanks guys - the isue has been resolved.
A close relative of my wife is trying to sell their house (110 years old) and the buyers inspector condemed the chimney. It is unlined and doesn't extend into the basement.
There is a connector pipe that goes from the first floor down into the basement to vent the almost new oil furnace and the propane water heater. ( here this wouldn't pass code) I suggested replacing both furnace and water heater with sidewall vent models. One guys solution was to build a new block chimney on the outside of the house for $6100.00
She found someone that will run an Stainless Steel liner down the chimney and all fuel piping to the basement for a lot less than either suggestions so far.
He even had the deciency to call me and explain what he wanted to do.
Thanks - Steve0
