R Value of loose fill asbestos...
Mark Eatherton
Mark Eatherton Member Posts: 5,872
Does ANYONE know the R value per inch for loose fill asbestos insulation?
Don't worry. I have no intentions of disturbing it. I just need to know in order to do a heat loss calculation.
I looked on Google, and all they did was warn me not to disturb it.
It is similar in consistency to mineral wool, and if I can't find a true R value, I will assume the R value of mineral wool loose fill insulation.
Mucho Gratzi.
ME
  • It's between
    R-4 and R-11.
  • Mark Eatherton
    Thanks Alan...
    I will assume the median.
    ME
  • RobG
    RobG Member Posts: 1,844
    R Value for asbestos
    This is what I found during a quick search "I tried the search term "Thermal Conductivity of Asbestos" and got this page (http://www.engineeringtoolbox.com/thermal-conductivity-d_429.html) for the 1st hit. After a few unit conversions, I came up with an R-value for asbestos mill board of 12.4 per inch of thickness. Loose packed asbestos came in at 11.8 per inch."
    Hope it helps
    Rob
  • Mark Eatherton
    edited July 2011
    Thanks Rob...
    I will take it into consideration.
    Funny how a slight change in syntax makes a World of difference :-)
    ME
