Steam duct coil
Jason_13
Member Posts: 305
I was wondering how to determine the capacity of a steam duct coil to determine boiler replacement.
I have a duct coil which measures 12 x 18 2 pass. This is installed in a vapor system which I thought a little unusual.
The existing boiler is grossly over sized as they have 4 burners blocked off.
Any help would be greatly appreciated.
If there's no better information
go by the size of the steam pipe feeding the coil. For example, an 1-1/2" pipe could serve up to 168 square feet.All Steamed Up, Inc.
Consulting0 -
Indirect Heating
Go to Resources at the top of the page, then click on Tech Stuff, then Hot Tech Tips the click How Indirect Heating Works,0
