Bell reducer in a main
Luv'nsteam
Luv'nsteam Member Posts: 278
I am assembling the forward main for my one-pipe steam system.  It is a parallel-flow main and begins life as 2" black pipe but needs to be reduced to 1 1/2" black.  I have more 2" pipe then 1 1/2" pipe and would therefore like to plumb it from the header with a 2" riser, 2" ell, 2" x 24" nipple and then use a bell reducer to bring it down to 1 1/2" in the horizontal, parallel-flow main.
Will using the reducer in this location cause water hammer or any other problems?  Does anyone know if I can purchase an eccentric bell reducer, threaded, 2" x 1 1/2"??
Thanks,
Mike
    Steamhead Member Posts: 17,899
    That bell reducer WILL cause banging
    and you should be able to find an eccentric reducer if you look hard enough.
    Consulting
  • Luv'nsteam
    Eccentric reducer
    Will the eccentric cause any issues or will it be fine, assuming it is installed in the correct position?
    Also, in searching through other threads, I found an Anvil catalogue but not a place to purchase Anvil fittings (and I do not care if I purchase it from Anvil or not, so long as I get what is correct).   Any supply house online that will sell me a single fitting or does anyone know of a place between Philadelphia and Reading, PA?
    Thank you, Steamhead.
    Mike
    The eccentric is the right part
    and there should be someone in Philly who carries them.
    Consulting
  • Luv'nsteam
    Then an eccentric
    Is what I will use.  Now to find one.......
    Thank you again, Steamhead.
    Mike
  • Rod
    Rod Posts: 2,067
    edited July 2011
    Try Anvil
     Hi Mike-
           It will probably be a special order item as they probably don't usually stock eccentric reducers in the size you want. You might also contact a local fire sprinkler contractor and ask them where they get concentric reducer fittings as they quite often use them in building sprinkler installations.
         Anvil Pipe makes a eccentric reducer in the size you want. I've attached the catalog page.  Fig.368 Eccentric Reducer 2 x 1½   Page 49
    http://www.anvilintl.com/SharedContent/Pdf/Literature_Catalog/Pipe_Fittings.pdf
    I got mine through F.W. Webb. Webb have outlets all over New England and New York though I’m not sure if they are as far south as Pennsylvania.  Call around to your big local suppliers and see if they carry Anvil.
    Anvil's headquarters is in New Hampshire and one of their plants is in Columbia, PA so if you get stuck, trying calling their PA plant and maybe they can give you a lead one of their supplier outlets.
    Anvil Pipe
    1411 Lancaster Ave.
    Columbia, PA 17512
    Phone: 717-684-4400
    Fax: 717-684-6868
    Good Luck!
    - Rod
  • Al_19
    Al_19 Member Posts: 170
    These guys
    are in Norristown, or will ship to you.
    Duff Company website with complete catalog: http://www.duffcompany.com/index.html
    Drilled down to fittings: [u][color=#0066cc]http://www.duffcompany.com/catalog/fittings.pdf[/color][/u] Scroll down to page 57.
    Hope this helps.
  • Jason_13
    Jason_13 Member Posts: 305
    Bell coupling
    Or use the bell coupling in a vertical application if possible
  • Luv'nsteam
    Location of bell reducer
    Riser height is an issue.  I do not have an eccentric or a bell reducer at the moment and I need more fittings and custom length nipples to boot.  That said, I will be making a trip to my favorite salvage yard to buy new fittings by their weight.  I will be looking for a reducer for this main, as well as, a take-off for a radiator and if I find a reducing ell of the correct dimensions, I may use that instead.  Thanks for the suggestion.  Tough to think about creating heat when its so dog-gone hot outside (was 113 on my trucks rear-view mirror readout when I got into it this afternoon).  Blah.
    Thank you,
    Mike
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,273
    I must have a dozen..........
    2 X 1  1/4"  eccentrics.   Sorry dude.  Mad Dog
  • Luv'nsteam
    Maddog,
    Are you bragging or complaining?  : )
    Do you have any 2" x 1 1/2"?  Do you have one 1 1/2" x 1 1/4"?  If so, I would be happy to relieve you of them/it for a reasonable price.  Let me know, please.
    Thanks,
    Mike
  • Luv'nsteam
    Rod and Al,
    Thanks for the info.  I will follow up with Anvil if I am unsuccessful with my "by the pound fitting/salvage dealer" in PA.  Thank you to both of you!!!!!
    Mike
  • jonny88
    jonny88 Member Posts: 1,139
    reducer
    if you cant get one i can fedex you one overnight,just get in touch
  • Luv'nsteam
    I will let you know
    Thank you!
    Dan, thank you for creating this website and for writing your books too!
    Thank you,
    Mike
