correct valve placement?
jonny88
jonny88 Member Posts: 1,139
my stupid ? of the day.on hot water systems we usually place valve on bottom of radiator and return 90 on the other side.i have also come across when we could not rough in the rad this way.instead we would put valve on top and return 90 on bottom but on the same side,bleeder is opposite the valve and plug the other opening on bottom of rad.both work,but which is the correct way.thanks.
    Steamhead Member Posts: 18,217
    For a small radiator
    either way will work. But I'd avoid using a same-end hookup on a long rad, since the water might not circulate all the way to the other end.
    Consulting
  • jonny88
    valve placement
    thankyou sir,your advice as always is appreciated
