Makeup water and a hot water coil.
ChrisJ
Member Posts: 16,892
My understanding is makeup water is always pulled from a cold water line. Why not the boilers internal hot water coil or a water heater instead?
Wouldn't running the ice cold water through even the boiler's own internal hot water coil help soften the blow?
Make up water
It wouldnt matter in that case because the water still would have to be heated by the boiler one way or the other.0 -
We have done this with
manual feeds for customers who had cracked previous boilers with cold fills. Automatic feeders are not rated for hot water.Cost is what you spend , value is what you get.
cell # 413-841-6726
Water feed
I don't know if its right or not but the guy who re-piped mine installed my water feed line in the return. Way on the other side of the hartford. I suppose I could crack the boiler if I tried hard enough, but I would have to really go out of my way to do it.
Yea, I insulated all that crap too. What a pain.0 -
black foam pipe insulation
Crash, did you use fiberglass or the black foam insulation on your condensate lines?
I would assume the black / gray foam would be perfectly safe on any pipes that always contain water?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Black foam
works ok on a domestic hot water 120 F. It would just melt on the condensate return 180-210 F. Use fiberglass on steam/condensate lines. My boiler and hot water heater are in a small room. Without insulation that room was very hot.
You might need some heat in the basement. Dont do the returns till last.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
