Makeup water and a hot water coil.
ChrisJ
ChrisJ Member Posts: 17,500
My understanding is makeup water is always pulled from a cold water line.  Why not the boilers internal hot water coil or a water heater instead?
Wouldn't running the ice cold water through even the boiler's own internal hot water coil help soften the blow?
  • Greg Maxwell
    Greg Maxwell Member Posts: 210
    Make up water
    It wouldnt matter in that case because the water still would have to be heated by the boiler one way or the other.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,430
    We have done this with
    manual feeds for customers who had cracked previous boilers with cold fills. Automatic feeders are not rated for hot water.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • crash2009
    crash2009 Member Posts: 1,478
    Water feed
    I don't know if its right or not but the guy who re-piped mine installed my water feed line in the return.  Way on the other side of the hartford.  I suppose I could crack the boiler if I tried hard enough, but I would have to really go out of my way to do it.
    Yea, I insulated all that crap too.  What a pain.
  • ChrisJ
    edited July 2011
    black foam pipe insulation
    Crash, did you use fiberglass or the black foam insulation on your condensate lines?
    I would assume the black / gray foam would be perfectly safe on any pipes that always contain water?
  • crash2009
    Black foam
    works ok on a domestic hot water 120 F.  It would just melt on the condensate return 180-210 F.  Use fiberglass on steam/condensate lines.  My boiler and hot water heater are in a small room.  Without insulation that room was very hot.
    You might need some heat in the basement.  Dont do the returns till last.
