Buderus mixing valve leaks
GW
Member Posts: 4,693
I have a new installation about 2 1/2 years old, the mixing halve for the radiant system is leaking a drip here and there out of the shaft of the mixing valve. The vendor says no warranty. can there be rebuilt? I have taked the Viessmann units apart to swap orientation but never a Buderus. Thanks, Gary
Leaker
Is there anti-freeze in the system, if so, when was the last time the PH was checked. Depending on what Manufacturer the valve is, there may be a repair kit, but if not, you are looking at replacement of the valve. Is there any way to tighten the packing on the valve? some valves will leak this time of year when the temp is taken off.0 -
ok
Good point, I can not remember if we installed anti freeze (I am not on the jobs all that much), i will ask my installer guy. It's an old farm house with funky additions, so there just may be.0 -
Mixing valve
You should try to make it part of your annual service on systems with anti freeze to check PH, and strength.0 -
Mixing Valve
I found it easier to just replace the valve , but I am sure it can be rebuilt . It was put together so it can come apart .. the valve I replace was seazed for lack of use , broken wire at the power source from when it was installed . I was not told of any rebuilding kits. Most heating equipment is is repaired back at the factory in Europe . . Just remember to return it to the same starting point . There is a set point gauge under the motor on the valve body .. I called tech support and they told me to call Charley which it their main field tech ... I can't remember what he told me .. SorryThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
