Anything new on the Mod-Con front?
SpeyFitter
Member Posts: 422
Since Lochinvar unveiled their Crest, and their firetube boilers, it's been kinda calm on the new products front lately. I noticed Viessmann Canada recently removed the Vitodens 200 WB2A for sale so they are no longer available, only the WB2B.
I've heard some inklings of exciting products to look forward to in the coming years but does anyone have any knowledge of anything coming down the tubes in the next year or so?
Are we going to see a smaller Vitodens? Anymore Combi Units from any of the manufacturers? Any upgraded or changed products or controls?
Hopefully...
SOME one will convince the powers that be (ANSI?) that these gems CAN be turned lower than 20% of their capacity...
METhere was an error rendering this rich post.
AFUE Ratings
This is nothing new, but I believe that manufacturers should also publish how they tested their equipment to get the published ratings. I think it would open a lot of eyes. Things are not always what they appear to be.0 -
Vitodens 100
Keep an eye out in August/Sept for news on the Vitodens 100. Viessmann now has a new Vitodens 200 with an upgraded control and lower turn down avail across the pond. Wouldn't count on the migration here until next year...
.There was an error rendering this rich post.
Thanks for the resposnes guys...
Chris, So I take it Viessmann is finally going to bring out the combi add on for the Vitodens 100? Whatever happened to the reported combi Vitodens 200 with built in tank? Is that coming out sometime soon? I also heard they may be discontinuing the 40 gallon horizontal stainless indirect possibly?
Greg, I agree about the AFUE ratings. I know of one manufacturer who seriously questions the percent of error that some manufacturers may utilize in their published AFUE ratings. I recall something along the lines that there is a way to come up with your AFUE, but you are allowed so many percent of error, and then what some manufacturers will do is up the published rating to the positive side of the error rating. So as an example, if they are allowd plus/minus 3 percent, and their rating comes up as 93%, they'd publish it as 96% or something like that. Please correct me if you know different.
Mark, perhaps it's dependant on the agency doing the boiler certification, or at least worth checking into anyways; how did IBC recently come out with a 5.75 to 1 on their new SL20-115 boiler that came out last year?There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
