smoking boiler
STEAM DOCTOR
Member Posts: 2,505
Good eve. I just finished installing steam boiler(gxha-100). upon firing the boiler smoke started coming from under the boiler. It was actual smoke not steam or water vapor. My eyes started to sting after a few moments. I shut down the boiler and will go back tomorrow. Is this normal? If not what would the cause be? What would burn? Could it be surface rust or something similar? I did a quick check in the fire box and the fire seemed normal. Thanks
smoking boiler
is it oil or gas? could be a draft issue or its oil on the castings from the manufactering process0 -
gas
slant fin galaxy gas boiler0 -
draft
i didn't have the time to test the draft. fire seemed to be strait/ maybe leaning bit toward middle.0 -
update
Ran boiler for 2 hours. The smoke and the burning smell almost totally went away0
