smoking boiler
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,511
Good eve. I just finished installing steam boiler(gxha-100). upon firing the boiler smoke started coming from under the boiler. It was actual smoke not steam or water vapor. My eyes started to sting after a few moments. I shut down the boiler and will go back tomorrow. Is this normal? If not what would the cause be? What would burn? Could it be surface rust or something similar? I did a quick check in the fire box and the fire seemed normal. Thanks
  • ed wallace
    ed wallace Member Posts: 1,612
    smoking boiler
    is it oil or gas? could be a draft issue or its oil on the castings from the manufactering process
  • STEAM DOCTOR
    gas
    slant fin galaxy gas boiler
  • STEAM DOCTOR
    draft
    i didn't have the time to test the draft. fire seemed to be strait/ maybe leaning bit toward middle.
  • STEAM DOCTOR
    update
    Ran boiler for 2 hours. The smoke and the burning smell almost totally went away
