I was reading the Bundy catalog
Charlie from wmass
Member Posts: 4,422
in Dan's library as I just got a few Bundy radiators and I saw in there an option to electroplate the radiators. Has anyone looked into this? With all the talk of radiator color I was curious how chrome or copper plated radiators would work.
cell # 413-841-6726
cell # 413-841-6726
Good grief
a copper plated radiator? I have enough trouble keeping the assorted copper cook ware and what not polished... !
It would look kind of neat, though...Br. Jamie, osb
It depends on what you want....
Metallic colors will reduce the output of the radiator, so if it is over sized, paint it gold, silver or copper. If you are borderline for BTU's, make it a flat, non metallic color.
I had a nice shiny copper radiator on the ceiling of my office at one time, and sitting below it felt good, but it never really seemed to kick out the heat I'd have thought it should. In a flash of genius (prompted by my wife not liking the metallic look on the ceiling of my office), I painted the radiator flat white to match the ceiling. Before I did, I measured the differential in temperature, and it was 3 degrees F. After I painted it, the DT increased to 5 degrees F. It then felt like I was getting sun burned from the panel.
So, as with any hydronic heating question, the only correct answer is, it depends :-)
ME0 -
I fully understand how paint color effects
the heat out put. I am talking electroplating a radiator. The whole dipping in a bath and fusing a layer of metal to it.Cost is what you spend , value is what you get.
cell # 413-841-6726
Same effect...
ME0
