Honeywell gas valves
Jim Pompetti
Member Posts: 552
I have had a few Honeywell gas valves leahk . Is this just isolated case or has anyone else seen this
When you say leak
what is leaking? What are the valve numbers? I have some information but do not want to post it here until I have more information from you.
Was the leak detected with a gas tester or soap and water? It is important as to what exactly you are referring to when you say leaking.0
- 109 Chimneys & Flues
- 71 Pipe Deterioration
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
