Corroded fins on condensing unit?
Robert O'Brien
Member Posts: 3,584
What would cause this? Not near salt water and no male dogs around!
Corrosion
Where on the cond coil fins is the corrosion? Bottom 2-3-4 rows? All over? Signs of corrision on the components in the control panel? How far from salt water?0 -
All over
5 miles from LI Sound. The corrosion is much less on the portion facing house,and is worse at the bottom 1/30 -
Robert
Hi! Rain runoff ? Sand erosion from splash back by rain? 6" of debris in the cond unit? Lots and Lots of male spiders?0 -
Lawn chemicals
from a broadcast spreader?Retired and loving it.0 -
Well I'll be!
Dan H. the AC Guy!!!!!!!!!0 -
LOL!
Broadening my horizons. ;-) What do you think? Consider the pattern of the corrosion.Retired and loving it.0 -
Thanks!!
Thanks to all for their input!0 -
Well now.
I think I just added another notch on my gun,thanks !0
- 15.8K Strictly Steam
