Corroded fins on condensing unit?
What would cause this? Not near salt water and no male dogs around!
  • Techman
    Techman Member Posts: 2,143
    edited June 2011
    Corrosion
    Where on the cond coil fins is the corrosion? Bottom 2-3-4 rows? All over? Signs of corrision on the components in the control panel? How far from salt water?
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,588
    All over
    5 miles from LI Sound. The corrosion is much less on the portion facing house,and is worse at the bottom 1/3
  • Techman
    Robert
    Hi! Rain runoff ? Sand erosion from splash back  by rain?  6" of debris in the cond unit? Lots and Lots of male spiders?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,708
    Lawn chemicals
    from a broadcast spreader?
    Retired and loving it.
  • Techman
    Well I'll be!
    Dan H. the AC Guy!!!!!!!!!
  • DanHolohan
    LOL!
    Broadening my horizons. ;-)  What do you think? Consider the pattern of the corrosion.
  • Robert O'Brien
    Thanks!!
    Thanks to all for their input!
  • Techman
    Well now.
    I think I  just added another notch on my gun,thanks !
