basi b10-3 or burnham mpo-84
polcat1p
Member Posts: 28
in Oil Heating
which is better for baseboard heat(,3 zonse) and a zone for a indirect?
i have a burnham allaince sl35 indirect, and i would like to add an odr.
thanks
thanks
polcat
There good restaurants,bad ones and great ones. Do the the ingredients make a difference? Absolutely,but the main difference is the chef! The choice of boiler between one triple pass and another is barely worth discussing!0 -
Agreed
you can't go wrong with either one, unless it's improperly installed. Both are first-class units.All Steamed Up, Inc.
Consulting0 -
bypass of p/s piping
i picked the biasi boiler, its comming monday, along with circs and a aq251 controll should i do p/s or a bypass to keep the return temp up? is a bypass just a tee from the s to the r with a ball balve?
thanks0
- 120 Geothermal
