combination Tee and gate valve
Luv'nsteam
Member Posts: 278
I want to place a main vent at the top of my tallest riser (King vent, I think it is called). I was intending on doing this by using a tee on top of the riser with a reducer bushing and nipple running vertically and the air vent on top, then a short nipple and a straight gate valve running horizontally. However, I do not have enough width to use this setup. My idea now, is to use a combination tee and gate valve where the tee would be vertical and the valve would be horizontal and it would be one single assembly. Without the nipple, I am thinking this setup should be much shorter than assembling the individual components to accomplish this. However, I have never seen or heard of this kind of valve. All of that said, has anyone out there in heating-help land seen such an animal? If so, who makes it or do you know where I can purchase this valve? Does anyone have any other suggestions to make this happen in a space-constrained application?
Forgot to mention tee and valve are 1 1/4".
Thank you,
Mike
Thank you,
Mike
venting a riser
how tall is this riser? before you go to all that trouble, i would suggest a gorton "d" on the top radiator, and hoffman 40's on the lower levels. of course the horizontal main to dry return must be also thoroughly vented with gorton #2's.
you will know when you have enough main venting by looking at the back-pressure, during the venting phase, on your good low-pressure gauge. add main vents until the pressure gets down to a few ounces.--nbc0 -
"master venting"
What you are explaining is called "master venting". Try searching the wall on the subject and use the quotation marks with your search. I read about it awhile back when I was trying to force some steam into a stubborn radiator. For me, master venting was not necessary. I tried the Gorton D with a TRV first, as it was the least work. Luckily it was successful.
Rod posted this diagram that shows 2 methods of riser venting, depending on what you have to work with.0 -
Thank you for the reminder
Crash. You called it correctly: master venting, not king venting. However, while you hit the nail on the head for the name, I am still left wanting a combination tee and valve in one body. If I am unable to locate such a beast, I will master vent my second floor radiator, which I am certain will still help. As I replace the mains, risers, run-outs, etc, I am also adding a line to eventually vacuum the air out with a vacuum pump. Think of it as a modern version of the Paul-vacuum system. I will use my tweaked (properly vented and only running on vapor) system for an entire season before I use the pump, so I have a base line with which to compare.
Thank you,
Mike0
- 120 Geothermal
