Steam pipes in wall
EdC
Member Posts: 3
I have an old Victorian that a customer bought and is re-habbing, he would like to keep the steam heat (for now) and would like to move some radiators around. Can I relocate an 1/1/4" steam line into an outside wall? It is a one pipe system that currently needs some tlc. Thanks Ed
a lot goes into piping
dont just move the pipe without making sure you have proper pitch and size. depending on how the piping will be done will determine what size and pitch you need. You can probably find the pitch and sizing charts on this site, or if you have "Lost Art" its in there. Enjoy and be careful those lines dont freeze with condensate if they are not pitched right.0 -
Thanks
Thanks, I have never installed a steam pipe in a wall, and got the okay by local plumbing inspector, no concerned on pitch in wall as it will only be vertical in wall. I would prefer not to install in wall, but the only alternative is to eliminate the radiator to second floor room.0 -
Pitch
The vertical pipe is of no concern, it is the horizontal runs that have to be carefully pitched so condensate can find it's way back to the boiler. Be especially careful of the short horizontal pipe on the second floor, that pipe and the radiator it feeds need enough pitch so water can flow back to the boiler. You might have to put shims under the radiator feet to get good pitch. Also make sure the horizontal pipe in the basement has pitch back towards the boiler.
The horizontal piping needs 1/2 inch of pitch in a 10 foot run, page 86 in "The Lost Art of Steam Heating" has this information. Make sure you don't create any dips where water can collect or all your hard work will reward you with water hammer (steam encountering pooled water in a pipe).
good luck,
3PSI gauge0 -
Move the steam, not the iron
You mentioned that the system needs some TLC and your post suggest that moving some radiators around may correct the defieciencies. My suggestion is to get the system working correctly first. It is much easier to move the steam rather than the iron.
Why does the riser to 2nd floor have to be moved?0 -
pipe in wall
new kitchen design, customer is gutting house but still wants the Victorian look of the radiators. I am roughing in heat lines to second for future baseboard heat upgrade. I tried talking him into new boiler and baseboard heat, his wife wants the radiators. Thanks0
- 120 Geothermal
