If our community has helped you, please consider making a contribution to support this website.  Thanks!
Old High velocity AC system
                    HVAC003
                    Member Posts: 10
                    We have a customer who has an old Dunham Bush / Spacepak High Veocity AC system installed in 1971. Can just the condenser be replaced? Can just the Condenser, Air Handler/coil be replaced without changes to existing distribution systerm? The existing system has been relativly trouble free since installation probably should be in a museum.
            Depends
The RIGHT way would be a new air handler and outdoor unit. That also could mean additional supplies for increased airflow. But if they refuse, you could find a "dry 22" condenser and slap it on that relic and hope for the best.0 -
            1971 ?
For an evap coil//blower , 40 years is RARE ! Let me say again, RARE!!! .Now,the system ducting,is a different story,depending on a few things.The " SEER " rating of the evap would be real low ! Maybe 6-8 ? Was SEER around in 71' ? Was it EER? O.K. now, the SEER of the "dry charged " is 13 and thats not good math !0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
