basi b10-3 or burnham mpo-84
polcat1p
polcat1p Member Posts: 28
which is better for baseboard heat(,3 zonse) and a zone for a indirect?
 i have a burnham allaince sl35 indirect, and i would like to add an odr.
thanks
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    polcat
    There good restaurants,bad ones and great ones. Do the the ingredients make a difference? Absolutely,but the main difference is the chef!  The choice of boiler between one triple pass and another is barely worth discussing!
    Steamhead Member Posts: 18,498
    Agreed
    you can't go wrong with either one, unless it's improperly installed. Both are first-class units.
    Consulting
  • polcat1p
    bypass of p/s piping
    i picked the biasi boiler, its comming monday, along with circs and a aq251 controll should i do p/s or a bypass to keep the return temp up? is a bypass just a tee from the s to the r with a ball balve?
    thanks
