King valve
USA498
Member Posts: 45
Planning on putting King Valves in a boiler repiping. 2" valve needed. What type of valve - Ball Gate etc? Where would one get it from ?
Thanks !
Thanks !
King Valve
Hi- A 2 inch full port bronze ball valve will work fine. Any plumbing store should have them.
- Rod0 -
I have been
using this model for one season now. No signs of wear so far. I think I would use them again. Dont forget to add a valve on the Hartford loop (same type) If you don't have the Hartford valve the Kings functions will be limited.
http://www.watts.com/pages/_products_details.asp?pid=3391
You are probably going to need a few drain valves also.
http://www.nibco.com/cms.do?id=2&pId=113&d-1342853-p=4
http://www.nibco.com/assets/TS58576HBV.pdf0 -
I was
Always told to use gate valves on steam to avoid melting the nylon seal in a ball valve0 -
Some ball valves
can handle steam. Check with the supplier or the manufacturer to be sure.
On the Watts that Crash mentioned, the WSP rating is "working steam pressure". So they're up to the job.All Steamed Up, Inc.
Consulting0 -
I've used ball valves that were steam rated
before, and had issues with them closing a year or two later..so i now prefer steam rated gate valves..usa made are the best..just my opinion..get burned by a product once or twice and its easy to decide on a particular thing..gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
