Burnham rs110 gasket for tankless heater
climbey
climbey Member Posts: 6
I am trying to find a new tankless heater gasket for a Burnham boiler model RS-110. If anyone knows the part number for this and also the heater coil and cover plate and where they could be purchased it would be greatly appreciated.  Thank you.
  • EddieG
    EddieG Member Posts: 149
    Where....
    Where you located?
  • climbey
    gasket
    I am in New Jersey
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    tankless
    If you can't find a Burnham dealer, Everhot makes replacement coils for just about any boiler out there and any supply house should be able to order one up for you, usually available in a couple days.
    Good luck
  • climbey
    online dealers
    Are there any online dealers where this part can be ordered. Thank you.
  • haventseenenough
    haventseenenough Member Posts: 61
    gasket
    Go to any P&H supply house, the one that starts with U comes to mind. Most tankless gaskets are standard sizes. Plunk down the 20.00 bucks and ask for one and it will magically appear.
  • billtwocase
    billtwocase Member Posts: 2,384
    gasket sizes
    most gaskets are not "standard sizes"  They are round, square, rectangle, and some even had no gasket, just thread into the boiler. Chances are if the supply house does not sell Burnham, they probably won't have a gasket for one.
  • haventseenenough
    gasket
    I stand corrected. Burnham offers this gasket kit in two sizes, rsa 85 - rsa 135 $ 10.48 and rsa 170 to 285 $ 12.85. Still easily obtained thru most local supply houses in N.J.
