Burnham rs110 gasket for tankless heater
climbey
Member Posts: 6
I am trying to find a new tankless heater gasket for a Burnham boiler model RS-110. If anyone knows the part number for this and also the heater coil and cover plate and where they could be purchased it would be greatly appreciated. Thank you.
Where....
Where you located?0 -
gasket
I am in New Jersey0 -
tankless
If you can't find a Burnham dealer, Everhot makes replacement coils for just about any boiler out there and any supply house should be able to order one up for you, usually available in a couple days.
Good luck0 -
online dealers
Are there any online dealers where this part can be ordered. Thank you.0 -
gasket
Go to any P&H supply house, the one that starts with U comes to mind. Most tankless gaskets are standard sizes. Plunk down the 20.00 bucks and ask for one and it will magically appear.0 -
gasket sizes
most gaskets are not "standard sizes" They are round, square, rectangle, and some even had no gasket, just thread into the boiler. Chances are if the supply house does not sell Burnham, they probably won't have a gasket for one.0 -
gasket
I stand corrected. Burnham offers this gasket kit in two sizes, rsa 85 - rsa 135 $ 10.48 and rsa 170 to 285 $ 12.85. Still easily obtained thru most local supply houses in N.J.0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
