keeps heating...
andy1
andy1 Member Posts: 1
i have shut off my Laars Endurance (all electrical so no power) BUT its still making hot water?? how can i stop it...
  • cesar77
    cesar77 Member Posts: 4
    cesarhvac
    if you turn off the power you will not have hot water, to save fuel you can install a timer to prevent the boiler from coming on ,unoccupied mode.
  • cesar77
    cesarhvac
  • Brad White
    Brad White Member Posts: 2,399
    If you have no power
    and you are still making heat, I would get in touch with Pope Benedict XVI (ratzi@pope.vat.roma) and your local media outlets in that order.
    Seriously, how hot and have you positively disconnected the power? If it is running to limit, get a pro in there now.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Are you sure you
    really turned it off? Are you speaking of there still being domestic hot water? As this could just be what is left in the indirect hot water heater assuming you have one.
    cell # 413-841-6726
