keeps heating...
andy1
Member Posts: 1
i have shut off my Laars Endurance (all electrical so no power) BUT its still making hot water?? how can i stop it...
cesarhvac
if you turn off the power you will not have hot water, to save fuel you can install a timer to prevent the boiler from coming on ,unoccupied mode.0 -
cesarhvac
If you have no power
and you are still making heat, I would get in touch with Pope Benedict XVI (ratzi@pope.vat.roma) and your local media outlets in that order.
Seriously, how hot and have you positively disconnected the power? If it is running to limit, get a pro in there now."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Are you sure you
really turned it off? Are you speaking of there still being domestic hot water? As this could just be what is left in the indirect hot water heater assuming you have one.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
