Disaster relief water filtration
michael_34
Member Posts: 304
Ok Wallies I need help here. This is not a heating question.
I have a friend that is working in Japan to help with disaster relief. He is trying to filter water out of a raging muddy river to supply drinking water. He is using a large R.O. system, but they have had so much rain lately that it is stirring up mud and rocks and plugging the RO filters.
I suggested he use a junk pump first with an in line filter in the hose. Maybe even some of centrifuge and then in to the RO system.
Thanks in advance
Michael
Thanks in advance
Michael
Check with Grundfos...
I'm fairly certain they have a portable water treatment system that they used in Haiti.
If worse come to worse, you could use a centrifugal sand filter, with a bag type of pre filter before it goes to the RO system.
http://www.valveandfilter.com/centrifugalseparators.htm
Kudos to him for being there to help. Tough job under the circumstances.
ME0 -
Mark
The man never sleeps : )
That sand filter is a great idea Mark! Thanks. Keep 'em coming. Your amazing.
Michael0 -
Another resource....
The Presbyterian Church USA is a major first responder when it comes to water filtration and supply in catatrophic situations. I suspect they probably have come across just about any problem, so your friend may want to contact them. They are probably right there in Japan with them or at pcusa.org.There was an error rendering this rich post.
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
