Disaster relief water filtration
michael_34
michael_34 Member Posts: 304
Ok Wallies I need help here. This is not a heating question.
I have a friend that is working in Japan to help with disaster relief. He is trying to filter water out of a raging muddy river to supply drinking water. He is using a large R.O. system, but they have had so much rain lately that it is stirring up mud and rocks and plugging the RO filters.
I suggested he use a junk pump first with an in line filter in the hose. Maybe even some of centrifuge and then in to the RO system.
Thanks in advance
Michael
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,864
    Check with Grundfos...
    I'm fairly certain they have a portable water treatment system that they used in Haiti.
    If worse come to worse, you could use a centrifugal sand filter, with a bag type of pre filter before it goes to the RO system.
    http://www.valveandfilter.com/centrifugalseparators.htm
    Kudos to him for being there to help. Tough job under the circumstances.
    ME
  • michael_34
    Mark
    The man never sleeps : )
    That sand filter is a great idea Mark! Thanks. Keep 'em coming. Your amazing.
    Michael
  • Another resource....
    The Presbyterian Church USA is a major first responder  when it comes to water filtration and supply in catatrophic situations.  I suspect they probably have come across just about any problem, so your friend may want to contact them.  They are probably right there in Japan with them or at pcusa.org.
