radiator paint what kind to use?
Dan_18
Dan_18 Member Posts: 20
Hey guys I'm stripping a cast iron radiator of many years of paint. When I'm done I would like to repaint it, its original color. It was a metallic silver. I remember reading some thing about the paint reflecting the radiant heat in to the room or back to the cast iron but I cant remember the details. As always thanks in advance. Dan F
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
  • Dan_18
    good to know
    Thanks guys! That information is very helpfull. I will paint it metallic silver after all to keep  with the original look  of the house.
    RE:radiator paint what kind to use?
    You're very welcome
  • Roland_18
    Roland_18 Member Posts: 147
    Rad Paint
    There was a long discussion on this topic a year or three ago. Someone said that silver is marginally worse and terra-cotta (colour) is marginally better. May have been someone with an FLIR camera who posted, I forget who.
  • radiant,conductive, convective
    heat is a juggler?
  • billtwocase
    billtwocase Member Posts: 2,384
    you can try
    high temp engine spray paint. I did mine years ago, and they still look great. If you can take them outside, that is the best way. The cast baseboard I left in place, masked off the floor and wall area and sprayed. The radiators went outside. I did mine in white, but an automotive store will have other colors.
