King valve
USA498
USA498 Member Posts: 45
Planning on putting King Valves in a boiler repiping. 2" valve needed. What type of valve - Ball Gate etc?  Where would one get it from ?
Thanks !
  • Rod
    Rod Posts: 2,067
    King Valve
    Hi- A 2 inch full port bronze ball valve will work fine. Any plumbing store should have them.
    - Rod
  • crash2009
    crash2009 Member Posts: 1,478
    I have been
     using this model for one season now.  No signs of wear so far.  I think I would use them again.  Dont forget to add a valve on the Hartford loop (same type)  If you don't have the Hartford valve the Kings functions will be limited.
    http://www.watts.com/pages/_products_details.asp?pid=3391
    You are probably going to need a few drain valves also.
    http://www.nibco.com/cms.do?id=2&pId=113&d-1342853-p=4
    http://www.nibco.com/assets/TS58576HBV.pdf
  • Steve_210
    Steve_210 Member Posts: 664
    I was
    Always told to use gate valves on steam to avoid melting the nylon seal in a ball valve
    Steamhead Member Posts: 18,188
    edited May 2011
    Some ball valves
    can handle steam. Check with the supplier or the manufacturer to be sure.
    On the Watts that Crash mentioned, the WSP rating is "working steam pressure". So they're up to the job.
    Consulting
  • gerry gill
    gerry gill Member Posts: 3,083
    I've used ball valves that were steam rated
    before, and had issues with them closing a year or two later..so i now prefer steam rated gate valves..usa made are the best..just my opinion..get burned by a product once or twice and its easy to decide on a particular thing..
    gwgillplumbingandheating.com
